255 hp
risknjtsi
Nov 18, 2004
NEWARK, New Jersey
my set up is built motor 272 bc cams 550 injectors 255hp fuel pump aeromotive fpr apexi turbo back and ssac fmic and g60 turbo now my question is im tunning with s-afc and i know my injectors are small for the turbo and im not planning on raising my boost past 10 psi while im breaking in my motor now my reading on my widebandreads 12,0-12.7 at idle and its running way to rich i havent taken the car out due to this problem that i want fixed my fuel pressure is 35 with vac hose i zero out my afc and even took it into the negative sand still running rich and no changes to my readings my question is is my fuel pressure to high should i lower it even though 35 psi is what it should be with vac hose if i remove it it goes up to 43psi any ideas please shine in ohh no boost leaks so im stuck here
i zero it out cause i was gonna tune it to my new set up so i was starting at zero but even at zero my car was rich at idle and even when i went into the negative on the s-afc i wasnt getting the a/f any higher than 12.7 at idle and it was so rich i couldnt even sit in the car LOL
So rich you couldn't sit in the car? If your SMELLING fuel that bad you might be about to catch fire.
