Walbro 255
255 litres per hour is 4.25 litres per minute which is 4250cc/min
in a 4 cylinder that's at 1062cc/min injectors (@ minimum pressure)
divide 1000cc by 1.5 and that's roughly 700hp give or take...
you have to factor in flow loss from the walbro as pressure builds ...
so in theory a 255 would be good for 700hp with the proper setup
Below is a comparison of the two pumps. Where the HP shines is when in high boost (base fuel pressure+ 1:1 rise for boost). We have small displacement engines and, hense, are more inclined to fall back on high boost to achieve a certain airflow (hp number). Also note the increase in flow w/ higher voltage (rewire mod) that spyderturbo007 mentioned:
A rewired HP flows around 54 gal/hr at 35ps boost and a base fuel pressure of 43.5:
54 gal/hr X 3.7854 L = 204.4116 L/hr
204.4116 L/hr = 3.40686 L/min
60 min
3.40686 L/min X 1000 cc = 3406.86 cc/min
At 35 psi boost, the rewired hp will provide just enough for 850 cc injectors at 100% IDC. or 1000cc injectors at 85% IDC. At 43.5 psi base fuel pressure and 85% IDC, 1000cc injectors flow enough for around 650 crank hp at 11:1 a/f ratio.
Same scenario w/ the "regular" 255; flows around 43 gal/hr:
. . . 162.7722 L/hr = 2.71287 L/min = 2712.87 cc/min
Just enough for 680cc injectors or around 525 crank hp:notgood:
_________________
An interesting thing to note: Lower fuel pressure to 37 and the hp flows around 58 gal/hr:
. . . 219.5532 L/hr = 3.65922 L/min = 3659.22 cc/min
This would take 1000cc injectors to over 90%. At 37 psi base fuel pressure and 90% IDC, 1000cc injectors flow enough for around 640 crank hp at 11:1 a/f ratio.
Point? lower pressure pushes injectors and not the pump. So controlling fuel pressure is a way to balance your fuel setup for not too much %IDC and not too much current running through your fuel pump.
