255 walboro hp pump=100+psi?
RaysTsi
323
Nov 4, 2002
Charlotte, North Carolina
I've had the pump sitting around for awhile in the box but never got around to installing it until my stock pump finally died. I already had a B&M fpr and fuel pressure guage installed(under hood) it was set at a nice 50 psi w/stock pump. After the install my fuel pressure guage is maxed out the needle goes as far clockwise as it can. Oddly enough now my car is running better and the walboro is quieter than the stock pump. I've got stock injectors, a SAFC2 and a datalogger; any suggestions?
1. get a real fpr.
2. turn the pressure down.
Your idle pressure will be high already with the 255 and that b&m (which will only allow you to raise the pressure, not lower it) and you are only making it worse with it still set for a 50 psi base with a stock sized pump.
