meliketoball
- 1,505
- 5
- Jan 4, 2007
Bay Area, CA,
California
I am looking to upgrade my wheels.
Currently they are Evo 8 wheels.
Specs: 17x8 with a 38+ offset.
I am looking for a wheel that will give me this kind of look:
I am looking at cobra rims that are 17x9 with a 24+ offset.: eBay Motors: 17" Gunmetal Morxchn Mustang Cobra wheels rims 94 - 04 (item 380116991961 end time Apr-18-09 23:58:15 PDT)
According from the offset wheel calculator, with current set up, it said my front wheel will stick out about 1 inch from the fender.
Current setup: 8 inches wide with 38+ offset.
New setup: 9 inches wide with 24+ offset.
"The clearance from strut housing to the inside of the wheel will be 1mm MORE
The outside edge of the wheel will EXTEND an extra 27mm"
27mm converted to inches is: 1.062992 inches.
You guys think 1 inch in the front sticking out will look dumb? Keep in mind, I am lowered about 2 inches, I do have negative camber and I plan to lower my car some more and stretch 215s or 225s on the 9 inch rim as well.
My theory with the negative camber and stretched tires, it would actually sink the rims more into the fender. (correct me if I am wrong)
I am not worried about the rears because I would like the rear wheels to stick out (also have negatie rear camber as well and has an aggressive look.) nor about my suspension bouncing because I am going to run coilovers. (8kg front and 6kg rear)
Whatcha guys think?
Whatcha guys think?
