20g's, 18g's and 16g's....Questions...
I would honestly stick with a Mitsu turbo. I know quite a few guys who have blown up there Garrett turbos and have a "warranty" on it. If I was going to have a warranty, I want it from the Vendor I buy it from. That way, they can send me a new one right away and can send the old one away to PTE (or whereever they send it to). I know Garrett turbos are the "new" thing out but until I see someone use it for a daily driver and get 30k miles out of it, I'll stick with a Mitsubishi turbo. :thumb:
OK, Im beginning to narrow my focus. How would a ported and clipped TD05 18g compare with a TD05 20g? How similiar is the spool and power charactertics? Also one guy pointed out the fact that the power band is more linear in a 20g and that an 18g still lost a considerable amount of traction in 3rd. Thanks in Advance. :dsm:
ShapeGSX said:
Well, I certainly didn't do it right the first time. First time, I got a Super 60/T25 turbo. Jeez, that was a POS for my goals. Got me to 13.7 in the 1/4, I think.
Second time, I got a small 16G. Better. Got me to a 12.4, eventually.
Third time is the charm, though. I've seen a lot of 50 trims doing a whole lot worse than I am with this 16G. Enough said? :confused:
Yes, you are definitely an exception to the rule. Your small 16g time is very, very impressive, IMO. :thumb:
It seems that you are probably maxing out that small 16g, right? Imagine what you could do with a maxed out 50-trim....... All the other 50-trim guys that are doing worse than you probably aren't pushing the limits like you.
Steve93Talon said:
Regarding 20g's and internal gates, stop sperading misinformation. Tort's internally gated 20g works perfectly fine and has gone 11.0s.
THANK YOU.
So I take it an internally gated TD05 20g will perform well without creep? Will there be a huge lag vs. power difference in an 18g and a 20g, both TD05 exhaust housings. :dsm:
