20G oil drain question
oneslowwdsm
858
124
Mar 30, 2009
Spring, Texas
Anyone know if I can use the stock t-25 turbo oil drain for a td06 20g turbo? (on a 7bolt motor) I know a 14b one should fit from what I've read but can't find anything for the t25 one. I used an aftermarket rubber one and it's leaking like no other and there is a kink in it which I think is causing oil to get backed up in the turbo and go past the seals.
Any input would be great.
You will have to slot the holes in the drain line to get it them to line up with the Mitsubishi housing housing.
