2 Oil Catch Cans Setup ...
Needed Parts:
1. Two metal custom made oil catch cans (8"long X 2.5"diameter)
2. 1 piece of 3/8" Kynar® Liquid/Gas Check Valves (usplastic.com part # 64175)
3. 7 pieces of female 3/8" NPT metal weld-in bungs (fabricated)
4. 2 pieces of female 3/8" NPT aluminum weld-in bungs (Summit part # SUM-220072)
5. 5 piece of straight 1/2" Hose Barb to 3/ 8" male NPT (Summit part # PRM-15153)
6. 1 piece of 90 Degree 3/ 8" Hose Barb to 3/ 8" male NPT (Summit part # TRD-2271)
7. 2 piece of 90 Degree 1/ 2" Beaded Hose End to 3/ 8" Male NPT (Summit part # EAR-984208ERL)
8. 1 piece of Steel Internal Allen Plug 3/ 8" NPT (Summit part # EDL-9127)
9. 3 feet of 8 mm ID HTS Silicone Vacuum Hose from ExtremePsi.
10. 5 feet of 10mm ID HTS Silicone Vacuum Hose from ExtremePsi.
To avoid touching the hood, both 90 degree fittings and aluminum weld-in bungs were modified to be less than 35mm in height as illustrated in last pic.
