2 blow off valves, one car??
TurboTsiThatFly
338
Sep 9, 2007
Randleman, North Carolina
So my question is could I run two bov's on my tsi talon still on the stock T25?ROFL basically having one:tease: open atmosphere on the intercooler piping beside the FMIC and one on the upper i/c pipe recirculating back into the intake? or would it cause a malfunction between the two bov's?? and the ecu read it not recirculating??:confused::talon:WTF
I don't think that would work and would be an absolute waste of time. If you are that hard up for projects I would suggest painting your interior, anodizing your balance shafts, or chroming your axles. ROFL
Merry Christmas!
why???:confused: If you wanna be a ricer and waste money go for it
It's the newbie forum that's what it's for. but if they both run off of the same vacuum line why wouldn't it work they would both be opened with vacuum and pressure. the reason i ask is cause i have EXTRA parts and just wanted to put them to use. Ive seen it done on highly modded eclipse's and talon's. like i said it the newbie forum that's what its here for so don't be a dick. and MERRY CHRISTMAS.
Yes, it'll work, but if you're going to do it I'd say recirculate them both. Unless Santa sees your wish list and gets you a GM MAF :) I'm personally too cheap for any BOV besides a 1g so I was considering using 2 if I had a turbo that moved enough CFM to require it. It may make a slightly different noise or be able to hear them open separately if that's what you're looking for.
It would be very pointless with your setup, but high HP and big turbo cars run two BOVs.
Since you're still running your stock MAF, just use a tee fitting to run them together, but having both receric will be a bit harder.
first of all check my pics you will see NOO RICE!! And once again ill ask can you run a blow through setup on the stock turbo?
A blow through setup.... with the maf and translator Gen 2 on the STOCK turbo? WILL IT WORK???????? i KNOW it wont work with the factory maf!!!!
Yes it will work. Two BOV's will also work. If you wanna spend the cash, go for it. I think it would sound cool, not gonna lie. Flame on.
Yeah, it'll work.
By the way though, just having one recirculated and the other venting won't help any. Metered air is still escaping if 1, 2, or eleventy blow off valves are vented(with a draw through setup)
how hard would it be to setup the maf and translator on the stock turbo? and the 2 bov idea put that aside. id rather not do it anyway.
