No Blow-off Valve???
93TSI_DSM
45
Jun 15, 2008
Holland, Ohio
Ok well.... my friend picked up an '91 Talon TSi FWD today and that thing was something ive never seen before. First there was like 1 bolt holding the cross-member motor mount on and one bolt holding the trans motor mount.:ohdamn: thats 1 problem. the second problem is there is an idleing problem it surges from anywhere between 1200-1500 RPMs to about 500 back and forth, only when idleing. Next problem there is a 3in down pipe...and that it no res, cat, or muffler at all(back pressure???) and last but not least im blown away by this sight. No Blow-off valve??? WTF is this right? i didnt think a turbo car would run, let alone drive with out a BOV. There is just IC piping going straight to TB and Turbo, no BOV at all. Car has a small 16g with 12psi of da boostness. Looking for a reason why the BOV wouldnt be on the car, and trying to figure out the Idle surge problem, it might be a Idle Speed Controller or Idle Air Control Valve or WTFever its called. Thanks for the Help Tuners.:thumb:
are you sure its not just hidden some where? when he drives it he MUSt get all kinds of compressor surge
first thing is get a stock BOV on there. then work on the idle
