2.0 cylinder head
92eclipse24
Jun 12, 2008
Nebraska, Nebraska
I have a 92 Eclipse 2.0L DOHC N/T. Will the head off of a 92 Turbo 2.0L DOHC work as the same?
Thanks, Jeff.
Yes. I'm pretty sure the only thing different about the two are the cams. But it will work,just put the n/t cams in.
Edit: Mr_Peepers beat me to it while I was typing.
You will need to use the old plug from your N/T head to plug the oil journal for the turbo feed line as well. Made the mistake once, and had a hell of a mess to clean up. You can also use the turbo cams for your N/T as well.
Mike
