1st gear pops out and grinds
drakedeming
Jul 14, 2006
bowie, Maryland
95 eagle talon awd turbo, 135k miles manual trans.
First gear will pop out and when trying to put it back in will grind. The only way to get it in properly is when coming to a stop right before the car stops gently slide it into first gear, then when accelerating from the stop it will not pop out.
My question is this, do i need to get a rebuild or new trans? Is it a simple problem with the shifter fork, and if so how can i check this? also this is my second car so if rebuilding is not extremely difficult i do not mind doing it myself, just need to know where to get the parts.
thanks
correct me if im wrong but most cars dont let u downshift from 2nd to 1st untill your going real slow... my tsi does the same thing but doesnt pop out or grind you have to come to an almost complete stop to shift into 1st... buddys rsx-s does the same thing
it pops out and grinds when i try to put it back in unless i put it into first rolling real slow to a stop. If i reverse then go to first like normal, when i try to move in first it will pop out and grind.
Sounds like 1st gear syncro needs some freshing up. When it starts to pop out of gear unless you hold it, its pretty much on its way out.
it is past that, i can no longer hold it in. Where can i buy a first gear synchro or is it even worth it? is it hard to install?
You can buy a first gear syncro from your local mitsubishi dealer. And yes it is very time consuming and somewhat hard to install especially if youve never worked on a transmission before. First you have to get the transmission out obviously, then you have to take the whole transmission apart. This can be a daunting task especially if youve never done this before. With so many parts in the transmission that look a like it can be hard to identify specific parts, and even more disturbing is the possibility of "mystery parts" when you go to put it back together. Plus you will need special tools to remove the syncro and set backlash etc. I would suggest getting a used tranny or having a shop rebuild yours.
i second that... ive seen the inside of a tranny and its just a headache take it to a shop and have them rebuild it and youll be good to go
ive rebuilt a few of my own trannies for my 92 and trust me....get the tranny out before its more then just the synchros or bearings..you may need a new 1-2 fork by now or new first gear...but even thats cheap compared to what it could be LOL...seriously take the tranny out and pay the money to get the problem fixed before it escalates.
I can double synchro your 1st gear so you can shift it in there while rolling with ease. I had one guy shift it into 1st on the hwy and it blew up his street disk, LOL
http://www.jackstransmissions.com/p...d=301&osCsid=b2161d968d8e08cfc8245b31bcd81dad
