1st Entry. April 2011 Spring Maintenance.
jeff24680
223
6
Jun 2, 2008
Allen Park, Michigan
Hello all,
I would like to start keeping track of what I do to my daily driver on a regular basis. I am finally going to start using the journal!
Anyways, my plans for this year were to work on my suspension and I am holding true to my goals. I have ordered a set of BC racing coilovers and should be installing them in the next two weeks. I will definitely be posting a review of these as there is little to no information on them within this website.
April Spring Modifications are as follows:
-BC Coilovers
-RM Rear Sway
-Energy master bushing set
-Complete OEM suspension replacement; consisting of all control arms front and back, inner and outer tie rods, sway bar links front and rear, trailing arms, every arm you can think of I will be replacing. All OEM parts ordered from https://www.oemmitsubishiparts.com
Mechanical Catalog - 1999 - Mitsubishi - Eclipse
Front suspension, Lower control arm, Lower control arm, eclipse, right, w/o convertible, w/turbo, awd - 1995-99 - 1 $145.20
Collision Catalog - 1999 - Mitsubishi - Eclipse
Front suspension, Suspension components, Upper cntrl arm, Upper cntrl arm Right 1 $104.80
Front suspension, Lower control arm, Lower control arm, eclipse, left, w/o convertible, w/turbo, awd - 1995-99 - 1995-99 1 - $145.20
Rear suspension, Suspension components, Ft lwr cntl arm, Ft lwr cntl arm Back - Awd - Awd 2 $52.76 x 2 =$105.52
Front suspension, Suspension components, Ft lwr cntl arm, Ft lwr cntl arm Left 1 $38.62
Rear suspension, Suspension components, Rr lwr cntl arm, Rr lwr cntl arm Right - Awd - Awd 1 $42.13
Front suspension, Suspension components, Ft lwr cntl arm, Ft lwr cntl arm Right 1 $38.68
Rear suspension, Suspension components, Rr lwr cntl arm, Rr lwr cntl arm Left - Awd - Awd 1 $36.51
Front suspension, Suspension components, Upper cntrl arm, Upper cntrl arm Left 1 $104.80
Rear suspension, Stabilizer bar and components, Stabilizer link, Rear suspension Stabilizer bar and components Stabilizer lin - Awd 2 $53.46 x 2 = $106.92
Steering, Steering gear and linkage, Outer tie rod, Outer tie rod, eclipse - power - POWER 2 $51.25 x 2 =102.50
Rear suspension, Suspension components, Trailing arm, Trailing arm Back - Awd - Awd 2 $25.24 x 2 = $50.48
Rear suspension, Suspension components, Trailing arm, Bushing, Bushing Back - Awd - Awd 4 $4.97 x 4 = $19.88
Steering, Steering gear and linkage, Inner tie rod, Inner tie rod, eclipse - power - POWER 2 $55.90 x 2 =. $111.80
Front suspension, Stabilizer bar and components, Stabilizer link, Stabilizer link Back - Gs-t & gsx - Gs-t & gsx 2 $56.06 x 2 = $112.12
On top of my suspension redo I have also done the following.
-Drivers door handle replacement with AZDaves reinforcement kit.
-LED interior lighting.
-Valve cover casket replacement and powder coat.
-Brake rotors and pads along with Powder coating he calipers
-Stubby antenna replacing power crap mast which is busted.
-OEM Keyless entry programming.
Pictures to follow!!
As promised here are some of the parts that have come in. Still waiting for Coilovers and Brake Kit. As well as second order of OEM suspension parts.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
