Maintenance/Spring Buildup
Fayt
515
15
Mar 26, 2005
Cleveland, Ohio
Ok... I moved into my house finally and have a garage to myself. Time to fix EVERYTHING.
Body work
New front bumper with cutout for FMIC
Fix dent on passenger door
Replace passenger fender
Repaint car
Carbon fiber hood
Shave rear antenna and washer squirter
Engine/Maintenance
Replace head gasket
Redo wiring in engine bay
Replace valve seals
Check piston rings
Resurface head
Oil leak from oil pan (possibly weld on bung)
Remove balance shafts
Parts
ACT 2600 clutch
New gaskets
DSMLink
750cc injectors
Walbro 255HP w/AFPR
Stainless fuel lines
Brian Crower cams
ARP main/head studs
New exhaust manifold studs
Wideband o2 sensor
Oil pressure gauge
Interior
Fix dash lights/gauges
Repaint or dye interior
Replace all plastic pieces and sunvisors
Fiberglass or carpet speakers
Fix trunk hatch
Fiberglass or carpet subwoofers
Sound
New components up front
4 channel amp for speakers
Misc
Realign rear tires
New rims and tires
Replace passenger fender cap
New hood pins
New front bumper
Fix radiator core support
Dual halo headlights
Yea, thats about it... so far I have taken the motor apart down to the block, just need to get a hoist to take it out. Thank god I have a garage and a daily driver! I'll be trying out that $50 paint job with the rollers on my messed up front bumper to see how it is. Turns out well, my whole car will be repainted in the spring!
I hope to run around 320hp @ the wheels come spring/early summer. Hopefully with the parts I have in mind and currently have it is possible. Wish my luck, I'll have pictures posted soon!
I completely understand where your coming from right now dude. My timing belt just decided to snap the other night for no reason. Only about 30k miles on it. I have had nothing but issues since I rebuilt it. So hopefully this time I can figure out what has been my issue since day one. I honestly think the head gasket was blown the whole time but was never able to confirm my suspiscion. Hopefully this way I can. I wish I could clean up the underbody and repaint the car as well but unfortunately my dad has been on this spree to get me to "grow up" or something. Buy a daily driver and make this my toy or sell it. I see where hes coming from. I just wish I could get a house and just tear my car apart like you are. It sure would be nice. Do a favor for me... take your time and do it right not just for you but for a fellow dsmer. Good luck and have fun while your doing it. Oh by the way, if you start it. You must finish it. LOL have fun!
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
