- Thread starter
- #26
GSXeclipsePSI
- 563
- 7
- Jul 7, 2003
New Port Richey,
Florida
Ok. Got home tonight pulled of the CAS and the T-Belt top cover.
A TDC the CAS was 180" out, which I figured since I swapped it since the car wouldn't go past 4000rpms with fuel cut or w.e. it was.. felt like fuel cut. Now when my CAS was set correct, I didn't know then my spark plugs where gapped wrong, my gapper was wrong, I rechecked and the gap was .20 before, maybe this was the cut out problem b4.
So I change the cas 180" out to TDC according to the timing marks, which I know are correct cause my waterpump was done at a shop and I was there to verify was all timed good since I was driving from NJ to FL and was stuck in South Carliona.
So now below is my UD crank pulley.
You can see in the pictures that the timing mark is way off of the marks on the T-belt case. This is where I see it when I time it!
