Ludachris
Founder & Zookeeper
- 8,878
- 4,725
- Nov 12, 2001
Newcastle,
California
So I'm starting to weigh my options in terms of changing out the stock bumper cover completely. I've always wanted to keep the factory look as much as possible on the exterior but the front bumper cover just limits you so much when you go racing. It allows too much air to go under the car and the FMIC opening could stand to be taller for cooling. The problem is all the aftermarket bumper covers look too... not factory. I guess I'm coming around to the idea that if I want better functionality I'm either going to have to deal with what's available or just deal with inferior aero and cooling.
On to the choices - I've found these two bumper covers for the 1Ga:
^ this one looks closest to stock but I don't know if I'm gaining much in terms of the FMIC opening. Does anyone have access to one of these? Can you measure the opening to see if it's bigger than stock?
^ this one is basically the same design as Collier's but it's made for a 1Ga. I think Collier took one that was made for a 1Gb (since there wasn't one made for a 1Ga at the time) and modified it. It obviously has better cooling properties and better aero but it's a little more extreme than I'd like to go. I'd probably modify it a little and eliminate the cooling vents on the sides just to tone it down a little. I don't want to completely lose my stealthy appearance.
Thoughts?
Thoughts?
