- Thread starter
- #26
Ludachris
Founder & Zookeeper
- 8,878
- 4,725
- Nov 12, 2001
Newcastle,
California
Oleg, I'll help you bleed the brakes regardless man. Just PM me or give me a call.
See, this is exactly what I had in mind.Chris - Check out this front bumper on this 2G race car. Maybe something like this would be good as well. If it was on a race car, I think it would be pretty good. There is all kinds of room there. Well, more than what we are working with now. Just another idea man.
I'm not quite sure what that upper bar is doing but yeah, nice design. I'll talk to Pagosa DSM about making one or three of something like that. He's been wanting to build a light weight bumper for his car.
Shure would be fun to smack into something with it at 5mph and test it out before using something like that on a DD.
they even thought about up high so if you run under another car your OK.
I'd like to do a rear bumper too, but first gotta get this one figured out. Need more weight savings in the front of these heavy beasts.I was thinking today that if someone is going to be making this you should add a tow hook to it. That way its mounted solid and if you get buried in the kitty liter you can get pulle dout with out losing any body work.
Any thoughts on a rear bumber?
Do we have anyone in the area that can go over and take some measurements? Better yet, do we have anyone here that could just buy the car?
I'm sure someone is in the Tampa area that wouldnt mind doing it. I believe thats where the car is.At the very least, the dejon option is not even welded at that center section. I wouldn't trust it against anything and not assume it would crumple inward quite quickly. They do say in their description that it offers NO protection.
I like the round steel, but I admit that I was thinking about the foam filler option or using some lighter square steel that could be molded then filled.
Guys, I am Currently designing exactly what your looking for.
Not more than a week befor Ludacris started this tread. I started designing a crash bar for the front of a 2Gb Talon. which if my measurements are correct, will bolt directly to Any 2G front end, While still alowing enough clearance for even the largest of 4.5" cores and fitting very neatly inside or below the upper portion of the bumper cover. after the 2g bar is made. I will hit the Junkyard and cut off what ever I may need to do a 1G bar.
I will tell all the details , As this is a very simple design and anyone with Fab skills can make this. Im NOT trying to get rich!
Just Like was shown on Page one.
Its Full Tubular Mild Steel. which wraps around the front of the car, and supports the upper portion of the bumper cover.
As the Stock bumper did, In one solid curved bar for Exceptional crash protection.
and yes It will be as Light as possible.
This is the 2G bar! I know the 1g is completly different!
We are Starting the Build with 1.5" OD. 3/16" wall thickness on the main crash bar. now the actual tubular mounts that will bolt to the stock bumper tounges will be smaller at 1" OD. with a 1/4" ID, to fit snugly agaist the mounting Bolt.
to crush these bars you must 1st shear the 1/4" bolt or Rip off the bumper tounges. before hitting the intercooler, or other parts of the internals.
what will happen is you will knock out the tiny 10 mill, nuts that are tack welded to the tounges, and use the Existing 1/4" holes to drop the mounting bolt through, and simple screw on the Nylon lock nut. simple effective and very strong.
Im kicking around the idea of Powder coating these in 3 colors or simply painting them with Demkote. In red, black or silver. considering on 75% or more of our cars, these bars will be seen in front of the upper portion on the intercooler.
Im just really busy with my Talon and S-10 Builds along with work ATM. so these are on Slow burn!. Gimme some time or make your own as I detailed above.
DougR
No, that doesn't offer any real crash protection. The goal is to have something designed that is lighter than stock, takes up less space to allow us to get more air into the radiator, and still offers crash protection. Aluminum bumpers won't work. We've come to the conclusion that a round bar, similar to the type and size used to create roll cages, would be the best solution. It's just a matter of having one designed.
Those would be fine for drag racing though I'm sure.
Chris, Erron and I have been running exactly what you're talking about for quite some time. If you would like something custom bent, welded and ready to bolt on just let us know and I'm sure we can get one together for you.
