Resolved 1G Topline Gasket Set?
triggerx
364
10
Aug 15, 2009
Gilbert, Arizona
Anybody running this set?
I planned on replacing every gasket and seal I could while taking this head off, however I dont want to put crappy gaskets on their just to have them blow.
My crankshaft seal and camshaft seal were leaking to the point that it caused my timing belt to break.
The set comes with a headgasket as well, but I dont plan on using it. Im upgrading to a 16g, so does anyone know of any good headgaskets to support up to 25psi?
Although I dont plan on running more than 15-20.
See I get to many mixed reviews with Topline.
Im not rich, and this is my only car, so Id rather not cut corners anywhere.
If anything Id prefer overkill.
Hell, I'd buy a 400$ timing belt if it meant it was never going to fail.
Ive decided, OEM for all my gaskets, and as for the head gasket, is there anything thats better than stock? I actually planned on getting the head resurfaced for a clean seal anyways.
Since Ive decided on OEM gaskets all around, what about this head gasket, the
OEM Multi-Layered Metal Head Gasket
https://www.extremepsi.com/store/product.php?productid=17779
Will it work out for my application?
The car is pretty much gonna be stock for the most part, except 3 inch exhaust, dejon intake, MBC,and the small 16g.
Plan on pushing nothing more than 20 pounds ever. And most likely lower than that
Lot of the pieces in the top line set are junk, might as well be thrown away.
Just get a fel-pro, cometic, or oem set.
Don't waste the money or hassle with the meticulous prep work its gonna take to run an MLS gasket. Spend the extra $ on ARP head studs IMO in case you do want to go upwards of 25 psi one day...they aren't necessary with your current plans, but things change.
Alright, I can't say I mind the extra prep work though if it means the car will be more reliable. However if the stock gasket will work just as good I might as well. However I hear the standard arp head studs are pretty much the same as the stock 6 bolt studs. So I should probably get the l1s right?
Keep in mind this work is being done with reliability,and longevity in mind first. Then performance
Its the deck surface that will be the problem, since you should pull the block to get it resurfaced properly. Pass on that unless you have the motor out IMO.
You can probably just run the stock bolts. If you ever decide to run really high boost down the road then you can always replace them one at a time then...
Ill get the head resurfaced. And ill do a oem composite headgasket.
@MY1GLaser
Im going to use the L19s for safe measure. They wont hurt, and chances are ill be able to reuse them. 2 years down the road.
You do have a point though, if im strapped for cash ill just go with the regular arps.
I still have to see how much damage the timing belt has caused.
If the pistons, valves, and all that are still good, Ill go L19s.
But MY1glaser you do have a point, i could just replace em later
However im trying to figure out what additional gaskets and seals ill need.
OEM Full Master DSM Gasket Set - OEM DSM Gaskets - Maintenance - DSM Performance Parts | DSMparts.com
or this one
http://www.extremepsi.com/store/product.php?productid=19912
Im assuming they are pretty much the same, but both sites dont have a complete list of gaskets it comes with.
I need the camshaft seals and front crankshaft seal. As well as a OEM composite headsgasket.
Timing belt so far is the only issue I had with topline. Pistons and gaskets water pump oil pump bearings have all been just fine. If you wanna good belt go with a power enterprise timing belt. About 160$+ or a gates for 140$.
@MY1GLaser
OEM Full Master DSM Gasket Set#-#OEM DSM Gaskets#-#Maintenance#-#DSM Performance Parts | DSMparts.com
or this one
I would buy the Oem set of those two.
i went the good insurence way and bought L19 headstuds 209$ and a mits mls headgasket 160$ i have a genuine evo3 16g fp headers and evo pistons so you could get away with arp studs deffenitly want studs go mits mls hg for sure if you want 25 psi and studs if your running 25 psi :sneaky:or higher
