1g throttle body rebuild (help inserting seals)
the_mork
2,619
26
Mar 10, 2008
Eau Claire, Wisconsin
So I'm having an awful time trying to get the seals into my throttle body, the tb is a 91-94 and the seals are from machV.
I've tried pressing the seals into the tb housing and into their rings and I just can't seem to get either way to work, it seems like the seals are bigger than either hole. I even tried pressing them in with the back of a screwdriver with no luck.
Does anyone have a tips or little tricks they use?
You removed the old seals, right? You will not reuse the metal ring from the old seals; the new seals are a complete replacement.
This seems to be where I went wrong. I thought I needed to put the metal rings back around the new seals. Its a bit late to try again tonight but I'll see if I can do it tomorrow.
I'll use the socket method and hopefully everything else will go smoothly.
Thank you.
