pauleyman
DSM Wiseman
- 11,587
- 5,441
- Nov 19, 2011
oklahoma city,
Oklahoma
If I'm this far into a motor I'm replacing seals which makes the gravity method unreliable. Easier to check it with the bolt hole with motor on a stand. Assuming youre keeping balance shafts that is.
The 2nd pics looks like its bent. Thr left side should be parallel to the right side. You can install the rails all by themselves and see that they all function.On the downhill stretch of putting this engine and transmission back together. When getting ready to install the shifter forks back in the transmission, we noticed that this part of the shifting mechanism was broken. It looks like it was spot welded before and one of the welds broke. I'm not a welder so not sure if this can be spot welded again or do I need to go on the hunt trying to find this part. It looks like a pain to take off.
Ordered a replacement and it should be here Wednesday.
