1g oil filter housing.
jeffreyinigo
65
Oct 6, 2004
Tucson, Arizona
hey guys i have a 1992 awd talon that shows very little oil pressure. it runs kind of crappy even though i just changed the oil. i think the oil filter housing is leaking, does a 1990 awd talon oil filter housing fit the 1992? reason i ask is because they both look different.
thanks
The 90 housing uses an external oil cooler, you will need the entire setup. If the housing is visibly leaking, the o-ring probably needs to be replaced.
oil leaking shouldnt mean it holds low oil pressure unless its leaking large sums of oil, your oil pressure being low sounds like a whole nother problem. Possibly worn bearings, clogged up oil system, or a poor working oil pump.
Does anybody know ware I can buy an 1990 oil filter housing. So I can slap some fittings on it and run some lines to the cooler i already have. Just trying to get rid of my coolent lines running everyware.
JNZ Tuning probably has the best price on that filter housing. I got mine from them and installed it this weekend, actually. :D
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
