Resolved 1G OEM wiring used for aftermarket fog lights?
SnowmanFD
142
8
Dec 11, 2021
North Seattle, Washington
First off I apologize if this is a dumb question i know close to nothing about wiring.
Im wondering if i could wire aftermarket fog light to the stock button? my car still has the plugs for the stock ones and i assume the wiring still works (still need to test it)
I was looking at buying something similar to this https://www.quadratec.com/products/...ueGtnbqagA7JF3KzpNgErdJhvD5N63L0aAlDeEALw_wcB
If not ill probably just buy a used oem pair.
Sure, one pin will be ground and the other battery voltage when the button is pushed in and the high beams are off.
There is a simple mod you can make to keep the fogs on with the high beams but as far as your question goes you can just wire the new fogs in.
Awsome! Im trying to learn basic wiring so ill try to figure the rest out myself.
As for the mod can you send me the link that has the list of all the little mods like that. Ive seen it somewhere but cant seem to find it now 😕
