Resolved 1G OEM auto Seat/seat belt install
Christo
168
311
Oct 2, 2002
Fairhope, Alabama
Years ago a swapped the oem seats out for a set of Corbeau A4 seats and their brackets. Recently I wanted to go back to the OEM so I had them recovered and went to put them in this weekend. I am pretty good about making sure that I keep all the hardware and parts when I do something like this but in my box of OE stuff it looks like I am missing a bracket or piece. The lap belt latch needs to bolt somewhere but I am at a loss, pretty sure it needs to bolt to the seat so it can slide on the rail when you adjust forward or back.
I have tried searching here and elsewhere without luck. If anyone has a picture, knows the part or can go take a look on their oem set up that would be great. TIA for any input.
I could also get u pics of the oem auto seat belt stuff. Mostly cause I have broken a pillars which are super hard to fine.
I have to adult today until, ahh I should be back by 3 tho
The bracket for the buckle goes under the bracket for the belt
Ah. Thank you guys.
Looks like the upholstery shop covered up where the other bracket mounts to the seat, am I seeing that correctly?
Ah. Thank you guys.
Looks like the upholstery shop covered up where the other bracket mounts to the seat, am seeing that correctly?
This is the oe seat cover, drivers side though
Sorry man I forgot about this. Its supposed to be 50 tomarrow, it's too cold n windy today.
So what pictures do you need? Mine should be fully intact.
Tag me if u can, so I see it when I login.
Just of the auto seat belt track underneath the a and b pillar covers. And if you can find where the motor is that actually moves it back and forth, that would help a lot.
Making progress thanks to you guys :hellyeah:
Thank you.
Cracked. I have my a pillar trim off on the drivers side I can snap a pic if that would help.
Thank you.
It would!
I hopefully got what u need fam. Its windy n cold here in Wisconsin im just gonna photo dump everything. If u need more specific, ahh I guess I could pull out backseat and the whole plastic thing.
Awesome. Just what I needed. Now I can see/compare and find what's missing.
