ist dwa
- 834
- 671
- Nov 5, 2009
Centerville,
Ohio
Okay I have searched and read the no start check list thread. http://www.dsmtuners.com/forums/articles-miscellaneous/217951-how-diagnose-no-start.html
Car was running on a daily basis, I was wanting to disable the MSD box so I put the wiring back to stock, car wouldn't start. Put the MSD back on car starts, extremly wierd, MSD tech support had no idea why that would happen. Rewired the entire ignition system just to make sure from the ecu to the PTU to the coils, still no start, wired the MSD back in now it won't start using that either.
I have spark at all 4 coils on my COP, checked with a proper spark plug gapping checker.
Noid light lights up on all 4 injectors.
Good FP at the rail.
I hear the fuel pump running.
Logger showing 55 degrees for the ECT, that is the temp outside tonight.
Added extra engine grounds just in case.
Plugs are BR8ES, gap was good, and they are perfectly light tan. They are about 4K old as well.
All connections at each engine sensor has been replaced recently and are good.
ECU was rebuilt by Steve last year, it was working until I started messing with this, so I can't see that going bad all the sudden. CE lights comes on then goes off, boost needle goes to 0. ECU is clicking on and off.
Threw another PT on there for fun, no help.
Physical timing is fine.
Never touched the CAS, like I said was running until I messed wtih the MSD. It is aligned correctly as well.
Compression is good in all 4 cyl.
Car runs E-85, injectors are fairly new about 4k on them. I can smell gas at the exhaust tip after cranking as well.
I have checked every single ignition connection and circuit about 100 million times.
I have air, the air filter is on and I havn't sucked anything in like a coupler or something stupid.
I'm at a lost, if I forgot something let me know, but I think I have covered all the bases. Any help would be appreciated.
