1g Maf Problem
DanthemanDSM
Jun 28, 2007
Oswego, Illinois
I have a 91 TSI AWD, I had a 2G MAF installed, I have 450c injectors and the car would rev very high in park and i didnt like how it ran since it has alot of miles on it. I currently took it out today, I rewired up the 1G MAF sensor and installed everything back to stock, Now The car wont even start, It wants to crank but no start at all, When i put the key in and turn it one click usually the boost meter would jump to *0* and the cars check engine light would flip on and then turn off before turning the car on, But now Im getting nothing at all. The reason I am doing this is because my end clutch burned out in my transmission and i only have 3 gears to drive on and i dont want to over work the engine, I Just was talking with my performance shop and he asked if i could check the spark, So im doing that right now..
Hmmm, usually when you don't see the CEL cut on at all when starting means a faulty ecu or connection that powers the ecu. I don't know why this would all of a sudded crop up after swapping back the 1g sensor. There's no voltage in the maf circuit that would over "fry" anything.
