Resolved 1g intake on a 2g head
Solution
the exhaust manifold will work but you will have to enlarge the 2 outer holes. The intake will bolt on and work, it will just cause alot of turbulence due to the rapid change in port size.
Solution
Ok so my best bet is to get both a 2nd gen intake and exhaust manifold.
The reason I am asking I found a replacement engine for my POS but its a 1g block and internals with a 2g head without the intake or exhaust manifolds. Freshly rebuilt.
thanks guys
i see your from fargo nd. i live in wahpeton nd, its almost a hour south. if your willing to drive i'll give you a 2g intake mani and exhaust mani.
thanks guys
The exhaust manifold will work just fine if you aren't trying to make a dectent amount of power. You can port the 1g exhaust manifold to match the 2g manifold also.
Yeah I would be willing to do that been there a few times. I have to make sure I get this engine but I will know for sure in the next could days. If you hold onto them that would be awesome.
no problem they're not going anywhere they're in storage. If you want them just pm me.... I'm on this site everyday.
The only thing I would take off a stock 1g and put on a stock 2g (besides the block) is the turbo (14b)
1g manual cams are a very slight upgrade.The intake manifold might be an upgrade.The TB is definatly an upgrade for 2g's.And any 1g turbo is better than the t25.
Agreed, the cams are a slight one but not worth the hassle of install. The manifold is an upgrade, but since it can't bolt up...it's no good. and I totally forgot about the TB
and the BOV (and I'm using a 1g bov :ohdamn: )
