Resolved 1G Intake Manifold Studs/Bolts/Nuts
athlete3344
459
134
May 1, 2010
Tampa, Florida
Im looking to order hardware for bolting up the intake manifold to head.
On extremepsi's website, I can only find the 7 smaller bolts and 1 larger bolt. I can not find the 2 studs and 2 nuts that go on the outer edges of the IM.
Can someone set me straight here on what exactly I need to order? I know for certain I need the 7 smaller bolts. Do I need 2 studs/nuts, or 3 large bolts?
And I checked what size bolt/stud/nut is this for the 1G. Just want to double check.
Thanks
Solution
Are the studs not already in place on the head? That's strange, to say the least.
If the head is completely bare of intake manifold hardware, these are the OEM pieces you would need to mount the intake manifold as it came from the factory:
(7x) M8 bolts - MF241256
(1x) M10 bolt - MF241284
(2x) M10 studs - MS401452
(2x) M10 washers - MF450406
(2x) M10 nuts - MF430122
I know on ebay there is a kit made by 316racing...i have not run these as i am going arp bolts that will be slightly longer than stock due to the heat barrier gasket i will be using
Solution
Exactly what I needed. Studs are there, nuts/washers are not. Thanks!
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
