1g head internals in 2g head?
crfridah
50
Oct 22, 2012
bristol, Connecticut
can you swap the internals from a 1g head into a 2g head that has bent valves would i have to swap everything if i could or just the valves?
The valves and springs are the same, 1g or 2g, Turbo and NT.
Depending on how bad the valves are, the guides may be cracked and need replaced. If that is the case, once the guides are changed the valve seats need cut.
Also make sure that all the valves are marked 6T or are stainless steel.
Sounds good thanks for the help!
