1G FWD vs AWD clutch pedal assembly
unior
519
Oct 10, 2002
Lancaster, Pennsylvania
Question: Are the 1g turbo vs non turbo and awd vs fwd pedal assemblies all interchangeable?
TIA
unior
Wrong. The difference is in the clutch/brake pedal. The turbo models are the same. The non-turbos are the same. The turbo models are not the same as the non-turbo. The turbo models have a bigger spring in the assembly.
I am fairly certain the accelerator pedals are the same.
wow what a big difference, i guess you should tell that to people who turbo there n/t to upgrade there spring. :ohdamn:
all it does is return the pedal back to the engaged position, it aint gonna have no effect on the trans or the clutch itself.
He asked if there was a difference. I simply stated the difference between them. If it were me in this position, I would rather get the right part and not possibly have to fight it later. If Mitsubishi put it there for the turbo models, it must be there for a reason.
