Clutch Pedal Assembly & Shifter Assembly
dsm03
1,171
8
Mar 4, 2007
Brandon, MB, Canada
Anyone know where to get the Clutch Pedal Assembly for a good price that is used but isn't squeaking? If not Part no. I can provide my dealership for a new one, I hate going into axe because the two guys there know nothing and are useless..
Along with the, same question with the shifter assembly.. It rattles and is very loose, makes the car seem old and worn out with these two things squeaking and rattling..
Soooo, Annooooying!!!!
If I read my diagram correctly, the 2G clutch pedal doesn't come in an assembly like the 1G. There are a couple bushings and a spacer you might consider replacing, but I don't know how much they will help: (2) MB316867 and (1) MB151139.
You can replace the bushings in the shifter assembly to stiffen it up. I did it to my own shifter and it felt terrific afterward. You'll need (6) MB829013 and (1) MB910176. EDIT: You may also consider replacing MB307949, a bushing in the bottom of the shift lever.
Make sure to grease the bushings when installing if you decide to do any of that.
  • For sale Carbonetics Carbon Quarter glass
    Bnew Carbonetics Quarter glass
    • jabo97gst
  • Wanted 1g Wtb: Palm pilot w/ MMCD and cable
    I am doing an old school build with my 1G and am looking for this ancient hardware. Preferably...
    • Jeff D
