Resolved 1G FWD Rear brake caliper rebuild
Stevens Talon
33
Apr 6, 2024
Tennessee
So after finally getting the kits in, I started a rebuild on both of my rear brake calipers. Note both where replaced with part store rebuilt ones a few years ago and I noticed that on the internal parking brake spring there was 2 diff ones. One caliper had a shorter one with a bigger top and small bottom the other caliper had one that was taller and the same size top and bottom.
The big issue is the one with the bigger spring, when releasing the parking brake, retracks the piston fully, the one with the OEM spring won't unless pushed on.
Any idea why this would be? The pistons and bores are clean and smooth and seals are correct.
I'm not quite following you. There are two return springs, one internal for the self-adjuster (13) and one external (22) to retract the parking brake. Which are you talking about?
The internal adjuster spring is the one im talking about
To be spefic i have 3 calipers 2 left and one right that does not have number 14 part and number 13 spring is large on 1 end and small on the other end i have 1 right caliper that has number 14 and number 13 spring is large on both ends and spring is taller. Im confused as to why
My original 91 AWD rears have a tapered #13 and no #14. I haven't taken any others that far apart to say what goes with what. The 90 FSM and the 92-94 FSM both show pretty much the same diagram and clearly it's inaccurate at least in my case.
After a lot of trial and error got it figured out. Not an issue with the parts was a issue with the new seals being a bit too tight. After being assembled a while it was fine
