Resolved 1G FWD Fuel Filler Hose size
Yamadaaaa009
49
15
Mar 7, 2023
Asia
As you guys can see, the previous owner of this car used some sketchy hose for the fuel line. Since I cant find an exact replacement here, I was wondering if it's okay to use universal fuel hoses and if so, what should I find in terms of length, inlet diameter, etc. If you could give sample pictures I'd appreciate it!
Thank you
Solution
I bought and nearly used this hose when I was uncertain whether my original hose would be okay to reuse. I returned it when my original was going to be reusable.
All the 1G AWD guys would use Gates 24716 or Napa NBH 1038 which is a 90-degree hose. The FWD is much closer to the 45-degree version, NBH 1046. Cut to length as needed to fit.
Solution
Perfect! Thank you very much!
