1G Fog Light W/Parking Lights Mod
I recently was browsing to try and find a tutorial about moding the fog lights on a 1G DSM. I know the 1G fog lights aren't as nice as the 2G, but still why not... I couldn't find anything except 2G stuff, which seems to only work right on a 2GNT, I know cause I tried on my 2GNT and it worked flawless, then when I tried on a 2GT, no such luck. So I played around and did a similar mod, wireing in the power to the fog lights from the parking lights, it works, but you cannot use the fog light switch. This is unexceptable in my book.
So here it is, its VERY simple. 6 Philips head screws and you can pull the gauge cluster surround out, disconect the 2 or 3 Switches (1GA Headlight Rise Switch, Fog Light Switch, Dimmer) from the surround.
Take the fog light plug, notice it has 4 wires going into it. Red, Green, Green/White, and Black. The only wires you will need to modify is the Green and Green/White. All you need to do, is tap these two wires together. I just stripped the sleve off about a 1/4" and soldered them together and wrapped with electrical tape. Put everything back together and there you have it. As you turn on your parking lights, the fog lights will be active on a 1G DSM and you will be able to turn them on or off with the switch.
If you prefer to have the fog lights as a running light, you could wire the Green/White wire into a switched positive. This in turn will activate the switch whenever the key is switched to the on position.
Enjoy.
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
