1G exhaust question, input needed.
dsmdeliveryboy
2,051
5
Aug 14, 2007
Medford, Oregon
Well, I'm on a pretty tight budget right now since I lost my job but I got a little bit of extra cash to spend on myself and was wondering if I would feel a power difference if ran the stock piping but ran a test pipe and a magnaflow muffler. I wanna get the muffer with a 3" inlet since I plan to upgrade to 3" piping once I get a job but just wondering if even doing that would entertain me with a little more power till then. I don't plan on making more than 300hp anytime soon as I'm into auto-x.
Mods:
-14b w/16g 7cm housing
-Ported Evo III manifold from Mach V
-Victory Performance o2 dump
-Balance shafts eliminated
-Kevlar timing belt
-ARP headstuds
-Metal headgasket
-ACT2600 clutch
-Jacks racing transmission clutch fork and fulcrum ball
-Solid shifter bushings
-DSS MBC@15psi
-Autometer boost and EGT gauge
-K&N air filter
-KYB struts
-Walbro 190 fuel pump
-Magnecore 8.5mm spark plug wires
I'm just really hurting for a little bit more power, thought this may be an idea.
See I keep hearing mixed things about it, some people say you feel a big difference since your eliminating your cat and putting on a no restriction muffler and other people say you hardly feel anything.. Can anyone give me some real answers?
Real answers a lot of people will tell you their opinons mine hardly could tell i had no cat and a larger exhaust piping, even when i went turbo, couldnt tell. Im not sure if your gonna find the exact answer you want just others opinons on their set up every car is different.
its really not worth it, wait untill you have the cash to do a full 3" and a highflow 3" cat, Im unsure about your emissions laws, but usally highflow cats only pass a visual inspection.
I'm in CA, I'm not worried about emissions I have no problem getting a dirty smog. If it will help at all I have no problem spending $60 to make a test pipe and buy a magnaflow. I have connections with the local kragen/o'reilly here so I get really big discounts. I would just rather here opinions from people who have actually done it than people who think it will make a difference.
