Badge023
- 76
- 73
- Nov 9, 2025
Ewing,
New Jersey
Been digging through wiring diagrams and was having problem with TPS throwing Code 14. I dug through diagrams and saw that on page 33 or so that the TPS ground reports to terminal 24 on the ECU. If the ECU itself is not grounded, will the ECU report the ground.
IIRC the ECU is not mounted and just laying in the compartment under the radio. Does the ECU need to be mounted to the body to report the completed circuit? Specifically Pin 24?. I'm currently replacing all the connectors that are seem to be made out of Doritos to get good contacts.
