Resolved 1g DSM ECU pin 11 function?
peon_slayer
259
34
Oct 6, 2008
grande prairie, AB, Canada
hey everyone I am wondering is someone happens to know what the purpose of pin 11 is on a 91 awd dsm. I know it has something to do with the abs but what exactly is it doing? I need to know because I am making a jumper harness for my link stormX ecu to plug into the factory harness and need to know if this wire is needed and if its not used if it will stop the abs from working or what signal I need to tell this wire. thanks for the help!
Solution
I wasn't sure when you PM'ed me but I did some searching and can confirm my supposition, it's to tell the ECU to idle up the engine to adjust for the heavy load on the electrical system that the ABS pump creates.
The details are spread across the 1G, 2G DTM, and 3000GT manuals.
Pin 11 is an INPUT pin so it is looking for a signal of some type, usually 0-5 volts. I haven't had a DSM with ABS so I haven't personally had any action with that particular pin.
Marty's correct it's an input to the ECU but like some of the other inputs the ECU is providing the voltage and the other side signals by pulling the voltage low.
Solution
you guys are awesom thanks so then this is hopefully something that my new ecu should be able to handle no issues may just need to add a relay in but hopefully not!
