1g coolant sensor wiring
wolf alchemy
724
14
Mar 4, 2014
kouts, Indiana
Help. Where do these wires go. The yellow is going to the middle prong, and the green is going to the outside one. If your unsure which prong is which i marked them in the thumbnail.
They eventually make it to the ECU to supply the coolant temp input. How they get there or the exact route through the chassis.... I have no clue but schematics can be found in the FSM.
Robert
Are you asking which wire goes on which prong? It doesn't matter as far as that goes, the sensor is just a thermo-resistor. As stated, they run into the wiring harness and to the ecu. They are pins 20 and 24 on the ecu.
