2G 1g CAS Install on a 95 GSX
Phardo
63
10
Jan 8, 2016
compton, California
I recently had my 95 GSX (7 bolt) turn off on and not want to turn on. I thought my settings were rested since I leave the battery unplugged. Called my tuner and had me do a live date stream as we noticed there was not RPM signal. He mentioned to me that I might have a defective Crank Position Sensor. So I decided to do a 1g CAS install. I purchased the plug off STM tuned and installed it when it arrived. CAS was installed at DTC, spark plug wires were set up to match the CAS firing order and check off the non 95/96 style cam angle sensor. Long story short, I have compression, fuel and spark car doesn't turn on. If I move the CAS around it tries to turn on but then turns off immediately. I'm not sure how to go on from this.
Any advise and tips would be gladly appreciated.
