1g camber solutions?
tylerdurden801
142
Nov 2, 2003
What good options to 1g guys have to get some (hopefully adjustable) camber up front. We have GC plates up front, which apparently suck, and I think I've heard of some Whiteline eccentric bolts that give you some negative camber, but it isn't adjustable. What do we do? :confused:
You need these.
RRE Camber Plates
I didn't notice anything in the link that would indicate additional travel gained from using these mounts. Any chance I just missed it? I wouldn't mind a solution that also gave more travel.
JIC coilovers. Have camber plates and travel is adjustable because the shock body length is adjustable. Expensive, but if you want more travel, that's it.
Specialty Products Company, Whiteline, & Eibach all make eccentric bolt kits that give +/- 1 degree up front. Whiteline has a rear eccentric bushing kit that has the same adjustment range.
