1g camber wear?
93AWDDSM
883
40
Jan 1, 2009
Vancouver, Washington
my 93 tsi(awd) only uses the inner tire, how do i fix the camber? can i get an alignment done? also my front shocks are bad can that play a part?
You need to purchase a camber kit if the vehicle is lowered, if not you will need an alignment.
DSM 1G Camber Kits - 1G 90-94 - Suspension - DSMparts.com - DSM Performance Parts
If your front struts are blown it will cause the front to sag more which will cause negative camber and you have a very high chance of ruining your hub bearings as well.
ok, well if i got the alignment done and then got new front struts a few weeks later would that be fine?
No, I would do it all at once. Because there is a chance you will need to get it aligned again after you get the new struts if they're blown that bad. Either way, just wait till you have all the parts.
