Camber kit for 2G uneven tire wear :(
I actually run the DIY mod and had the front aligned by a Mitsu dealer. With 1 degree of negative camber all the way around, I no longer have excessive tire wear issues after 6K miles on my current setup. I'd do the DIY mod and have everything professionally aligned.
If the bolts become loose, a shim can fall off, but a washer can't.
Shims are used because they are easier, not because they are better.
- Jtoby
You're riding on suspension components fabricated from sheet metal. Do you think enough force will be generated to crush or somehow deform steel washers?
