1g BOV problem?
fatness_42
68
Aug 5, 2008
Council Bluffs, Iowa
I'm not sure if my BOV is functioning properly. I had the pipe that it is attached to off the other day(stock pipe) and noticed that the valve appeared to be open. I was not sure if this is normal or not? Would the valve be open because it opened when I stopped moving to shut the car off? Or should it still be closed at idle?(before the car was shut off) I would guess that it should be closed even at idle but I wasn't sure. Thank you for any help.
    • Sdcryan1
