1g awd fuel pump hard to find localy.
Hesh724
373
Feb 7, 2009
Hopewell, Pennsylvania
Pretty sure fuel pump died. car acts like its out of fuel but runs for a second then shuts off. i get no fuel pressure at the AFPR. Car wants to run but no fuel pressure. that could only be the pump right? if it was clogged it wouldnt eve try to run right? Also i have a GSS 315 walbro and if fits into my stock sending unit without any modifications. but the ones autozone is try to sell me is coming up for my car but its bigger and it doesnt connect the same. now im seeing a gss341 can someone post a picture of a real life 341 all the website pictures have the rubber nipples on the fittings so i cant see if its the right one. The style i need is in the picture.
Thanks to anyone that will help!!!
or could someone post a link to a good site that has for sure the correct one i am so scared to drop 100 bucks unless im sure.
Did you actually try jumping the relay to make sure that the pump isn't just loosing power.
GSS 341 is a Walbro 255 High Pressure pump for a 1g AWD. 3 seconds on google netted this picture:
It will work for you.
Im still using the stock wiring exept whats on the plug for the pump its self LOL
Verify that the pump is the problem and that the ecu isn't cutting power. It is common on 1g's for the ecu to cut power to the pump after a few seconds if the caps are going bad.
Ya thanks Dexterholand 04 but again it has the rubber nipples on it so you just showed me one of a million pics i DID FIND that have the rubber nipple on them so i cant see the connector. but i got one and it works great So thanks.... thanks for nothin LOL also read the site rules if you dont have a real answer, Then dont answer at all.
I believe the GSS315 is just a low-pressure version of the GSS341. Fitment *should* be identical.
Also, please cut the name-calling bullshit- especially when you're the one asking for help. It gets you nowhere around here.
Thanks JusMX141 "Also, please cut the name-calling bullshit- especially when you're the one asking for help. It gets you nowhere around here."
Talk about bull shit. you guys dont even enforce the rules on the people who deserve it.I asked a simple question he didnt even have to try to answer. he didnt even read my question and gave a sarcastic answer. thank go im not on this site much or i would lose hope on humanity haha. again the moderators here are swing door Mfers. stand up for your self and get pushed down again right?
