1G and 2Gb CAS on 2Ga car
_Madman_
327
Oct 14, 2004
Riga, Europe
Does anyone know how hard it is to add a non 2Ga CAS sensor to 2Ga car?
I can get a 2Gb one quite easily right now, but I heard it requires some drilling or something and that 1G CAS is much easier to swap.
Has anyone done something like this, which one should I get? I will do timing adjustments through ECU, so I'd rather go with 2Gb CAS which is nonadjustable, if it's not a major PITA.
I will try to study those diagrams more deeply. I'm not very good at wiring stuff. But I am hoping I will still be able to use the CPS and 2Ga CAS as well.
I want to switch to 98/99 ECU, but for now, I need to be able to keep the old ECU working. So I will need to come up with a scheme, or switch of some sorts.
Do any other cars aside Turbo DSMs have a 1G CAS sensors? Galant's GTi's/Colts? 1G turbo cars that are being parted out are incredibly rare in Europe.
I don't mean to thread jack but i do got a question that is very related to this... if people say that adding a 1g CAS can replace both the Crank angle sensor and the cam angle sensor... why not just split the output signal from the crank angle sensor in the first place?
    • Sdcryan1
