can i put a 2ga cas on a 2gb?
Vancho
75
Oct 9, 2011
spokane, Washington
I have a 7 bolt engine that's from a 2gb and is missing the cas, I also have a 7 bolt engine that came from a 2ga, and the cam angle sensors on a diffrent place, on the 2gb its on the left side of the camshaft, on the 2ga its on the right, goes right on the cam gear, is there a wire I can put in that will allow me to hook up the 2ga cas to the 2gb wire location, let me know if anyone has done this or knows of that wire or how its done thanks :)
Hate to bring back a thread from the dead, but i figure its better than starting a whole new one.
I swapped a 96 7-bolt into a 98 7-bolt body/harness.
If im understanding this correctly, I need to cut the plug off the harness, cut the plug off the CAS (which is under the intake cam, right?), and splice the wires together.
And still swap firing order?
Sorry, trying to fully understand this before I start cutting things.
Also, the 97-99 CAS connector is different from the 95/96 CAS connector, so to it looks like ill be cutting both off and hard wiring it in.
I made an extension harness last night with RED, BLUE and BLACK wires.
If you are interested, We have that adapter new in stock for $32.99 + $6.20 shipping, its not yet listed on the website, but i can do that soon. ;)
