Resolved 1G Alternator Removal
hondakilla90
108
Jun 15, 2003
Does anyone have something with pictures i can follow to do this job. If you dont have pictures its ok i need all the info i can get on how to do this job. So anything will help.
:talon:
Fairly easy. There are two bolts on the right side of the alternator, loosen those. Use the adjustment screw to take some tension off the belt and then take the belt of. Then take the bolts out the rest of the way. They are kind of long and you'll probably want to take the splash gaurds off from under the car. Becareful you might break these taking them off. Disconnect the wiring going to the alternator too.
Then the alternator pretty much slides right off. Be sure to have it tested at Autozone to be sure it doesn't work.
