91eclipseDSM
- 84
- 0
- Apr 1, 2012
Salem,
Oregon
Hey everyone, so im having an odd problem with my 1g. The alternator seems to not be giving me any charging voltage, its a simple enough system... plug and positive so im lost as to where the problem is. The car just runs off the battery until it cant sustain then it dies, i can jump it and it will run for 30 secs then die. When i pull the positive the car dies instantly. I have tried 2 different alternators, new power cable from the battery to alt fuse and still nothing. The when jumped and running the voltage at the battery and alt b post are the same at 12v as if the alt isnt giving me anything. Any help is appreciated!
all inside fuses- good
alt fuse-good
positive from battery- connected
upper plug- connected
belt tension- good
alt fuse-good
belt tension- good
