Alternator issues
gsxeclipse97
1,255
Nov 7, 2004
Cedar Park, Texas
Well my battery light is coming on and then goes off. I checked the voltage and it's putting out over 14 volts. So I thought it was the battery but it was tested and is good also. So any ideas what could be causing the problem. It's a gallant alternator and it's been workin fine untill the last couple of days. Also the car was having a very difficult time starting the last couple days and is not quite doing it now but still is having some issues.
bad ground to the starter? kinda what it sounds like since its having a hard time to start, but it could be just a dying alt. i went through 4 in ten days LOL shop i bought them from had just all shitty rebuilt ones i guess
+1 check your grounds, especially the one going from the battery to the bellhousing.
Also, keep in mind, just because an alternator puts out fine on a bench test, doesnt mean it is going to work correctly on the car.
ditto, i just found that out, had advance test it, said it was good, put it on my new motor etc, and though things where ok, till one day was working under the hood, with the hatch up, and went to start the car, and it was dead, thought it was the battery nope, took the alt to a shop and they found the voltage regulator was toasted. Now i have a new alt and things are working much better then before. Id have your alt checked, it could be your dead short like it was for me.
