1G ac fan problem
volcomsnow245
492
May 4, 2011
chicago, Illinois
First of all I've looked on every single post trying to find this answer and nothing's clear so here it goes. Today my battery died because of me leaving my amp on all night and it's -3 degrees right now. So I charged the battery got the car running and I go to turn on my ac fan as usual by using the ac controls from inside the car. Nothing, the fan doesn't turn on, so I ran a jumper and the fan is working but doesn't come on using the ac controls all of a sudden. Suggestions?
Fuse is good, I'm buying a new relay right now. Any other suggestion before I blow $30?
Replaced the relay still not turning on. I'm so lost.
There are 2 relays that turn that fan on but, a total of 3 relays for the cooling fan circuit. One relay is the FAN MOTOR relay and the other Condenser Fan High-Low Change Over relay and an Condenser Fan motor relay, for the other a/c condenser cooling fan motor. You sure you replaced the correct relay? Also check Fuse#5 20Amp fuse should be hot at all times. Recheck you electrical connectors and make sure the pins are making contact.
