Resolved 1G 90' ecu in a 93' nt
choard
43
Aug 20, 2008
newberg, Oregon
i have a 93' nt car which i am installing a complete turbo longblock in. I have a 90' turbo ecu. will this work? if so what wires to add or pins to move. i have already added knock, wastegate solenoid and mas. thanks
Solution
http://www.dsmtuners.com/forums/art...4-ecu-swap-into-1990-dsm-ignition-wiring.html
This article will help you but if you are putting a 1990 ECU into a car with a 1993 wiring harness then you only have to swap pin #6 and pin #14, the tachometer and the ignition power transmitter do not need to be changed like when putting a 1991-1994 ecu in a 1990 car.
This link will explain how to remove the ecu pins so you can swap the wires.
http://www.dsmtuners.com/forums/art...w-remove-replace-pins-harness-connectors.html
Solution
