1G 90 eclipse gst ecu pinout
fupkid
May 22, 2014
farmington, New Mexico
I am looking for a pinout of the 90 gst ecu. I have looked at the one in vfaq but my wire colors do not match. I just realized my car has a 93 ecu and I would like to get the two wires swapped over.
Here is the connector for my ecu where pin 6 and pin 14 should swap. look at the wire colors.
So do what luv2rallye suggested and use a multimeter to check that the wires running to those pins actually go to what they are meant to go to.
1990 ECU Pin 6 = Idle Position Switch = 1991-1994 ECU Pin 14
1990 Turbo ECU Pin 14 = MAF Active Filter Reset (Turbo MAF Pin 1) = 1991-1994 Turbo ECU Pin 6
Wire colors really don't mean anything aside from making it a billion times easier to identify. All the wires could have black insulation and, if wired correctly, would work fine. Good luck diagnosing anything though.
This explains how the pins are numbered for DSM ECUs: http://www.dsmtuners.com/threads/how-to-identify-ecu-pin-numbers.246467/
